1G EPROM ECU help?
speedy_talon28
364
3
Apr 1, 2006
elkhart, Indiana
Well, I bought a rebulit eprom ecu and a chip on ebay, I put the chip in it and hooked it up but when I tried to start the car it wouldn't. The engine was tring to start but didn't so I put my old ecu back in and it fired right up. Is there a right and wrong way to put a chip in????? With the eprom ecu, the engine was acting like it was tring to fire on 3 cylinders but like I said my original ecu works just fine
Sounds like ebay did you wrong. There is only one way to hook up an ECU, as the pinouts are size co-ordinated. It sounds like they sent you a bad ECU. Contact the seller or post some negative seller feedback.
If you still have the factory eprom chip, put that in and see if it starts.
I bought a bad eprom off ebay too, mine started a small fire
These "upgraded chips" are all over ebay. Buy from someone legit like www.dsmchips.com or pay for DSMlink and be done with it.
Looks like this one? The "sticker" has been put on using MS Paint or some other cheap program.
--------------------update-----------------------
I contacted the company that I bought it from and they said send it back and they will exchage it for a non-turbo ecu + 200.00 refund because they don't make or they haven't heard of a epom ecu for a 1.8 non-turbo
------------------edit-----------------------------
The company found an 1.8 non-turbo eprom ecu which they would make an even exchange which makes me happy to hear that :)
