dherron
- 87
- 4
- Jun 12, 2004
Uhrichsville,
Ohio
Well i have a sad story. To all of you who think synthetic/synthetic blends are any good you are way wrong. I recently did an oil change on my car and used some new stuff Mobil1 Clean 7500 10w-30. Well at the beginning I could tell a definate amount of oil pressure lose. I had about 10 dealer mechanics tell me that the lose of pressure was made up by better flow and better protection. Which is complete bullshit in my books. Well today I noticed a noise and I thought that I spun another B-shaft bearing. Well it ended up being a rod bearing. So I took apart all the rod caps and all the bearings were pitted and showing copper. So I showed my boss and he said that the synthetic oil flowed so well that it basically did lubricate the bearing enough. So here I my word to you all not to use Synthetics. Use Castrol GTX 10w-30. There is no better conventional oil. And conventional oils have worked for a hundred years so dont change. I have more questions but that is for a later post.
