engine wont lean out!!!!
Coder24
346
Jan 16, 2006
Marysville, Ohio
ok I have a greddy emanage and I cannot get the car to lean out. Also my check engine light keeps flashing on and off after the install. Basically the car is running dog rich and wont lean out...Its dumping it into the exhaust it seems...im getting fed up. and im also getting idle surge like an sob... I have 2g pistons in my 6 bolt 91. stock turbo with a fmic.
Why don't you see what your engine is trying to tell you
ECU Code Checking
then do a boost leak.
Ill have to check this... Like it runs Fine but with a little surge and a little rich. but when I goto Restart it...it doesnt want to for about ten minutes...the emanage is Shooting me a Red light under active(which means error)
