ECUflash Idle pegged lean/dies out
CanadianTalonTC
582
97
Jul 8, 2011
Lethbridge, AB, Canada
1). Any boost, vac, or exhaust leaks?
No leaks whatsoever at 25PSI
2). Verified mechanical timing?
Yes, twice. Unless I'm utterly out to lunch it's perfect.
3). Verified base timing?
Yes
4). Ignition system
COP or Stock Coil: Stock coil
Wire brand and Age: Stock/unknown
Spark Plug brand, type and Gap: NGK BR7ES .028"
5). Motor health (Compression Test)
Cylinder 1: Brand new build
Cylinder 2: Brand new build
Cylinder 3: Brand new build
Cylinder 4: Brand new build
6). Performed basic throttle body adjustments?
Idle Switch: Integral to TPS in a 2g??
Throttle Cable: Adjusted
TPS: Adjusted to .6275V (the closest I could get. Next it jumps to .6475 in ECUFlash).
BISS: Cannot get vehicle to idle long enough to warm up and adjust it.
7). Compression ratio 9.0 to 1
8). Any known bad sensors or brittle wiring?
No.
9). Any DTC/CEL codes?
No.
10). Electrical system
Car off (not running): 12.6V
Car running: 13.5-13.9V
11). Base fuel pressure and injector values
Base Fuel Pressure: 42PSI (no vac)
Injector Size (cc/min): FIC 850
12). Properly calibrated and configured wideband sensor
Sensor Brand: AEM UEGO
Calibration Date: ?? It has 1 hour of runtime on it.
13). Type of fuel
Type: 91OCT
Percent of Ethanol: up to 10%
14). Watched ECMlink how-to videos? Searched ECUflash and found what I can. No luck.
I have a log attatched as well. I am having trouble getting it warm and such as well. I've included the base tune that a guy made for me too.
Modifications are:
Intake/intercooling:
- K&N FPIK (Installed)
- GFB BPV (Installed)
- FP 4" Intake (Installed) Intake is currently removed, open turbo
- ETS FMIC (Installed)
Turbo/exhaust:
- FP 71HTA (Installed)
- FP Manifold (Installed)
- FP Drain line (Installed)
- SS Oil feed line (Installed)
- Punishment Racing recirculated external gate 02 housing (Installed)
- Tial 38mm wastegate (Installed)
- 3" catted downpipe
- Thermal R&D catback
Fuel:
- Battery relocate
- Fuel pump rewire
- Fuel Lab AFPR with gauge (Installed)
- Walbro 255lph
- FIC 850cc injectors (Installed)
Interior:
- Everything grey to be swapped to tan (Installed)
- Simple deck wired into the stock sound system
- Fuse box relocate
Exterior:
- Respray it Plasma Blue Pearl
- Powdercoated purple calipers
- 35% tint
Suspension/Tires/Brakes:
- Ground Control coilovers over Koni yellows
- Hawk HPS pads (Installed)
- EBC Rotors (Installed)
- Gold Sparco Assetto Gara 17x8
- Hankook Venus RS-3
Tuning:
- AEM Wideband (Installed)
- AEM Tru boost (Installed)
- Gauge cluster pod (Installed)
- Tune via Tactrix 2.0 (Installed)
- Ceddymods SD with Omni 4 bar and GM IAT (installed)
Engine:
- Weisco 9.0:1CR Pistons (Installed)
- Eagle H beam rods (Installed)
- Manley forged crankshaft (Installed)
- ACL Tri Metal main/rod bearings (Installed)
- ARP Head studs (Installed)
- Felpro gasket kit (Installed)
- HKS 264/264 Cams (Installed)
- Emission delete/general underhood cleanup (Installed)
- Powdercoated purple VC (Installed)
Drivetrain:
- ACT 2100 (Installed)
- ACT Streetlite flywheel (Installed)
- ACT TOB (Installed)
- 6 puck disk (Installed)
- RTM Shifter base bushings (Installed)
- RTM underhood shifter bushings (Installed)
Basically, above 1200ish RPM it runs great as far as I can tell (I can't actually drive it cause of the idle problems) Fuel looks good, it bounces around 14.7 on my wideband. Below, 1200 it pegs lean, idles rough and will idle for about 15 seconds when warm then dies out.
My ISC tested fine, I've adjusted my TPS and throttle cable. Car used to have cruise and has a non cruise cable now. Emmisions are deleted as well as ABS.
I've attempted to adjust my BISS but I can't get the car warm enough/run long enough to perform the procedure so it is at 2 turns from bottomed out with ZERO leaks coming from it or anywhere else for that matter that I can find. I am honestly not sure what exactly you guys need to see for a log either. So just let me know what you want or any information I can give you and I will supply it! It's been nearly 3 years since I've driven this thing, getting close haha.
