Engine Wont Fire !!!!!
xtremedesires
Jun 9, 2006
Twin Lake, Michigan
I drive a 1g eclipse , fwd n/t, anyways I replaced the coil, plugs,ptu, crank sensor and camshaft sensor, I am still not getting spark. It is rolling over and getting fuel but wont fire. PLEASE HELP!!!!!!!
did you check the timing belt by chance.. i know it sounds silly but if the belt is smoked and its not turning the cams the cam angle sensor will not turn either, and if the cas is not moving your ecu will not send a signal to the coil packs.
Nor will it fire the fuel injectors or energize the fuel pump. His is getting fuel so you can rule out the timing belt.
Recheck all electrical connections and check the ecu for leaking capacitors.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
