Engine temp. guage not working!
TurboFever
100
Aug 1, 2005
Paterson, New Jersey
I dont know when but my temperature stopped working. It is the stock one that is with the fuel level guage. The fuel is still working but not the other side? Can anyone help me fix this??
i'm betting the wire that connects to the sender got disconnected. look for a single blade connector sensor on the thermostat housing.
If for some reason the wire or sensor that connects to the thermostat is cut or broken, you can spend a little money at Advance Auto and get yourself a water temp gauge for cheap. I ended up buying a cheap-o sunpro gauge and mounting it in the center console. Here's the link to the gauge, and a picture of my setup. The lighting kinda sucked, but you get the idea.
http://www.partsamerica.com/ProductDetail.aspx?categorycode=3342D&mfrcode=ACN&mfrpartnumber=CP8207
