420A Engine Swaps
Chances
Jun 16, 2023
Buckeye, Arizona
I’m just starting my mechanical journey and decided to go DSM. My question is can a 4g63t Engine fit in a 1999 Mitsubishi eclipse gs? If so does anybody know a good source to buy those engines from?
It's not easy but it's doable.
It took me a month to cut and fully weld. It was no hack job you have to swap wiring and if you don't swap the dash there's a wire you have to cut. Power steering and all has to be swapped along with crossmember and sub frames.
