2G Engine stalls while hot
DAN RUSE
Jun 24, 2019
BUCHAREST, Europe
Hello everybody,
I need an opinion on what might be the issue with my 1997 Eclipse GS...The engine starts just fine, runs evenly with no hesitations or any other problem...until it get warmed up...then, if i turn it off and start it again, in 4 - 5 seconds it dies...and so on...last time, i had to wait for it to cool down (at the gas station :banghead: ) for about 45 minute...
...what i did so far was to check and clean up the MAF sensor, changed the temperature sensor, changed the spark plugs wiring, bought the crankshaft position sensor but not yet replaced it)...did not put it on any tester yet...
Any clue on what to check for?
Thank you
i just noticed your in Europe. So you have the non-turbo 4g63, right?
there is a fillip screw on the top of the throttle body it may have a black plug . take the plug out and back off the screw a quarter of a turn and see what happens.
Hi there,
Thanks for the reply...yup, the engine is a non turbo version...I've got the manual, i did found the page you posted here and i am planning to have the car tested soon at an authorised workshop that will , hopefully have the sofware - never did it before - the check engine lamp in the board does not remain on, it only came on just before the engine stalls and thats it...i was hoping someone did encounter this in the past and could provide me with an answer coming from their own experience...nevertheless, thank you for your time...I will keep you posted on what happened...
Dan
you have the chrysler none turbo motor that is a different set up
The Euro spec non-turbo eclipse came with a 4g63
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
