1G ENGINE REBUILD
4G63Tlove
Oct 16, 2015
Klamath falls, Oregon
Okay guys so I got myself a 1g with 84k miles and this Mods
20g turbo
Hks wastegate
Intake English racing front mount Intercooler
Apexi Boost Controller
Down pipe n cat back
I did a compression test and here are the results
1.120 2.90 3.120 4.120
So cylinder 2 is really low and I thought dsm had 164 across and I don't know if the previous owner did a low compression build or what but anyways
I just want to rebuild the engine I want to leave the head stock and just rebuild the button to oem specs because I know they can hold 400 to 450 reliable. What do you guys think?
1G (90-94) T/E/L 2.0L Turbo engine
Compression ratio 7.8:1
Standard compression 164 psi
Service limit 121 psi
A rebuild wouldn't be a bad idea..the stock parts can go a long way..if your upgrading make sure your have a good tune.And keep up service maintenance it goes a long way
It is strange that a engine with low miles has compression that low.Are you sure you are testing it correctly?
A leak don needs to be run... it could be a slight bent valve in #2 causing low compression.
A leak down needs to be run... it could be a slight bent valve in #2 causing low compression.
True, but seeing as how the other 3 cylinders are below the service limit I would bet a "refresh" is in the OP's future.
A good OEM rebuild is not a bad method. Make sure you have the head freshened up at the same time. Also, I'd recommend getting a good set of forged pistons and trash the OEM cast ones. They are the weak link in the bottom end (*assuming 6 bolt). The rods and crank are solid.
Its a waste hanging forged pistons on stock rods, 6 bolt or otherwise,
With a 20g and decent tune, the NPR 63DT will support that.
The reason the other 3 cylinders could be low , is bigger cams and/or the timing belt off a tooth.
At 84k miles, The timing belt was changed once.
Pull the balancer and front cover line up the crank marks, then check the cam marks.
I disagree with your first statement but I don't want to get into an argument.
The 3rd and 4th statements could be true but nothing in the original post said anything to suggest that. Seems like pure conjecture. :idontknow:
