Engine Management
JimmyJ
70
Feb 19, 2003
hey whats up, I just recently installed a Evo III 16g turbo Walbro 255lph fuel pump, 550rc injectors, and an hks hi power exhaust and an injen intake. I was just wondering what ecu or engine managment upgrade will i need to get my car running just right as far as timings and fuel delivery.
Thanks alot,
You are running 550 injectors and a big16g without any type of fuel tuning? I don't think that is very safe. You might want to get that AFC pretty quick.
I have the same setup as well....I'm woundering if I'm not really shooting for 11's or lower.....what kinda fuel managment should i go with? I don't want to spend $500plus to get the dsmlink......would the SAFC2 be the best way to go? I don't get the timing adjustment tho...... :(
If you don't want to spend the $500 or so on DSMLink I would go with the safc since it seems to be the most popular. But as far as the DSMLink being $500+ I would say its worth every penny & more. You have to remember DSMLink also does datalogging, so an safc and a pocket logger setup would be around $500 as well by the time you add up the cost of the software, cable & palm.
MEGASQUIRT.....go to 2gnt.com to find out more. Ordered my setup to be built about a month ago for $285...much more advanced than the SAFC-2 as well as more capabilities. ill be running a T3/T04E 50 trim with 550s, and i found, by searching, this is the most affordable and one of the most effective ways to go for the 2G n/t. Using the SAFC-2 is for fine tuning, and if your not careful it will advance timing to much.
  • Wanted 6 bolt NT water pipe
    • chrisman287
