engine fuse blows at WOT
sexeclipse
Aug 14, 2004
Waterloo,
background:
i got the cars transmission rebuilt by mr tranmission
when i recieved the car back there were a few new problems with it
everything has been corrected except for this and i really need to fix this before i dream of putting the car up for sale.
whenever i go WOT the engine fuse blows. I can push the gas to anything but WOT and its fine but WOT it blows. I have also tested out if maybe the pedal was causing a short for some reason by turning just the ignition on and putting the pedal to the floor, but the fuse does not blow. Any suggestions?
if nothing else, take it to where you just had it serviced and tell them that it didnt do that until you got it back from them
if only it was that simple
they claim they didnt touch anything and after them having my car for 9 months and 6 rebuilds i just want the car to stay away from their. Anyone have any ideas?
they took forever to order parts and for whatever reason as soon as id get the car back when it would shift gears it owuld slip HUGE like 2000 rpm. So the clutches needed to be replaced. The car was never put under any hard acceleration for the slipping to occur it just happened. They also broke a lot of stuff on my car (2 speedo sensors/gears,2 02 sensors, hood pins). Just a very poorly run shop and i think they used the cheapest shittiest parts possible.
Drop the car off. Tell them it worked when you gave it to them, and now it doesn't. They're required by law to fix it. You've got proof that they don't deserve to have a business. I'm sure they won't want to be black listed. They will fix it.
Hint: Go in during peak business hours and cause a HUGE commotion ;)
