Engine Fuse blows after install injectors
xxShaneOmac
423
Jan 2, 2007
Everett, Washington
I just installed my 880 injectors from stock.
Took off the AN from the fuel rail and afpr
Unscrewed the 3 screws and took out the injector wires
pulled the old and replaced w/ new and new orings etc.
put back together,
Drove it around did a few pulls fine,
This morning i drive after its warm and I hit the gas, it boggs and dies,
Fuse gone,
After 3 hours i replace it and drive other 15 mines,
At a stop it bogs and dies again, Repaced it on the spot.
Dies when i turn on and try and start,
It only dies when im gas'ing it.
Can I goto like a 30A fuse instead of the 20a?
Thanks
Its called "Engine" on the fuse box
It only blows the fuse when you are under acceleration? I don't recommend a larger fuse. Check the ohms on your injectors and look real close to see if nothing is pinched or touching something it shouldn't.
Good Luck
Well,
Acutally
The Injector Wire harness,
The clip part, Wouldnt fit between my fuel rail and on my injector,
So i backed out the fuel rail and put the clip on the injector and then tighten it down,
So it mayb squished the clip from the wireharness agaisnt the injector,
And when The engine tourqes it pinche and surges.
  • Wanted 6 bolt NT water pipe
    • chrisman287
