Engine Fitment
Kenchinito
Apr 21, 2011
Panama, Florida
Hello,
I'm trying to purchase a 4g63t, but the store says that 94-96 engine doesn't fit 97-99 chassis and vice versa. How true is that?
I'm looking for a 1997 4g63t+awd manual tranny (tranny MUST include transfer case)
What's the difference between reading vendor pages and searching for "stores"?
Vendors are stores that pay a fee here to advertise (<--- click for some to see an example an some specials) an as a general rule are usually trusted sources of parts he's a full list of the Vendors here(<--- Click) an their Rating from members here:thumb:
And many vendors also have quite a few tech articles available (Magnus and RRE come to mind).
To answer you question if the engine you buy is a 7 bolt motor, you'll be fine. The only difference that you will most likely encounter is the intake manifold + throttle body as well as the cam sensor. You will need the 2gb style cam sensor for the 97, which is located on the passenger side of the intake cam. The 2ga (95-96 engine) sensor is located under the intake cam gear.
