Engine Chugging, Need Help BADLY!
er00msivarT
30
May 25, 2004
Easton, Maryland
Heya people,
To start i have a 1999 eclipse GS (420a). I have a AEM CAI, Greddy Header, and Custom Cat Back 2.25 Exhaust. A couple months the problem started when my car started misfiring. I replaced the plugs, and wires. That didnt stop the misfire so i went back in, and replaced the plugs, wires, gromings (is that what the are called? the round gaskets that go around the plugwires under the valve cover), valve cover gasket, and the ignition coil. Ever since then i have felt like the car chugs, but i have not had any misfires. The car seems to run fine and doesnt ever stall like a misfire or anything. When the car is at idle that is when it chugs, it does it when its in gear or in park. My car idle jumps from about 500rpms to about 750 rpms depending how long it has been running. Now i was wondering what else could be causing this chug sensation. Im thinking the Catalytic converter so im gonna take that out and put in a test pipe. Also when i put my exhaust in they put the o2 sensor back in behind the catalytic converter so im gonna have that taken out and tied up on the exhaust. Since this is currently throwing a CEL would this be causing the chug? What are some other things i should check? Air Filter? Gas Filter? Any input would be greatly appreciated, this is really starting to get to me. Thanks for all input.
*Edit* The chug sound is loudest when you put your head down by the passenger side headlight and front tire.
Travis
I have 96 gs and it did the same thing after the car backfired with the help of nitrous and when I got to work this moring I put my drb to it and it came up as a bad map sensor code 0108 but aslo my car would not pass 4 grand it would act like a rev limiter since the map sensor was always peg at 5 volts.
everybody has a suggestion or a opinion just try it till it works or take to the dealership
