Engine chug with new transmission
2G95tsi
Dec 3, 2007
El Centro, California
I just put a transmission in my car and now at 3 plus rpm it has a huge engine chug then it's back to normal, but it only happens when my foots all the way down in the peddle, my boost is also being a little sketchy where should I start looking to fix the problem?
What exactly is the boost doing?
You could a boost leak test. And are you still using the stock boost regulator solenoid?
