Whitetal
- 149
- 1
- Nov 24, 2002
Fresno,
California
Ok so I plan on rebuilding my motor. I've got 2 blocks, my original and new. This rebuild is not for racing or high horse. Just normal daily car. My question is do I have to get oversize bearings and grind the crank journals if there is not any damage? Does the crank need to be grinded and polished no matter what? I read here that if there are no scores on the journal then you could just replace bearings with stardards and it will be ok. My motor is around 140K miles. It is out now with out the head. Just the block. I can spin the crank easily by hand. Crank spins freely. I'm guess this is pretty good then. My new block was very hard to crank. It is by itself as well. I found that the bearings were pretty scoured and smashed. Crank jounals had some scouring.
