engine build what head gasket should i use?
bmwracing_6
163
Sep 22, 2006
Stuart, Virginia
I am building my engine with wiseco pistons and eagle rods I had it bored 20 over to clean out the cylinder walls and have a nice tight fit. But I still need to buy an head gasket I was thinking of the copper gasket I forgot who makes them but what else is good for my application after the rebuild and is there a certain size I should use? I will be running the stock 14b until this summer when I have to money to invest into the supporting mods for my holset turbo I have. I plan on making around 500hp on this setup with of course many other mods to support the holset turbo.
for your goals, go with cometic, but be SURE to have the head and block level, or it will not last long.
I would also like to add if you do get this make sure you get someone who has fooled with these before. I have had problems getting these to seal properly which has caused problems, I have always had to torque my head down to atleast 95 ft/lbs to get these to seal atleast. As with the mitsu mls have always torqued them down the 85 ft/lbs and used stock head bolts in the past and never had a problem. I am not saying that you should use stock, definately get arp. Just a little info from personal experience..
I have been using mitsu metal HG for a while, and installed on a few cars.
Its a great HG, and you cant go wrong with it.
Go to auto zone or where ever and get you some copper spray as well.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$ Brand New GReddy timing belt no box 175$ Like New Magnus...
    • GST2012GSX
  • For sale 2g 2G Black Steering Column Plastics
    2G Black Steering Column Plastics $35 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G AC Delco Starter ( Tested & In Great Condition )
    2G AC Delco Starter ( tested ) $45 + shipping and paypal fees* fits 2G GSX & GST with manual...
  • For sale 2g 2G Black Center Vent & Switch Plate
    2G Black Center Vent & Switch Plate $40 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Hatch Seal
    2G Hatch Seal $35 + shipping and paypal fees* some small imperfections but still solid with no...
