- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 50-trim
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- 3" Intake, 3G MAF, GReddy Type S bov, sealed catch can setup with check valve on PCV side. SCM DBB 5031RE 50 trim, EVO III Exhaust manifold, JMFab o2 housing recirculating Tial MVR wastegate. Plugs gapped at .28, Fluidyne Radiator, SPAL pull fans, SPAL fan controller, RRE 2.5-3" downpipe with test pipe, Custom mandrel 3" catback, FIC 1650 HiZ injectors, Aeromotive A1000 -6AN AFPR, Walbro 450Lph, Prothane motor mounts, SBR Street FMIC, Solid shifter assembly bushings.
- Mods-Engine
- HKS 264 intake cam HKS 272 exhaust cam, 3g revised lifters, BC titanium valve springs and retainers, Cometic metal headgasket, ARP head bolts and studs, Ferrea Competition valvetrain, Eagle Rods and Wiseco Pistons 20 over and 8.3:1, BSE kit, Frontline Fab Ball Bearing Gerotor oil pump, Moroso oil pan.
- Mods-EMS & Logging
- ECMLink V3, Zeitronix ZT-2 Widband O2 with EGT and Boost options.
- Mods-Drivetrain
- RRE X clutch with street disk(ACT 2600 with lighter pedal), 11.25lbs RRE No Name Flywheel with .612 step height,
TRE tranny with Jon's Road Race setup, Evo III 1st gear and input shaft, double synchronized 2nd, HD 90’ 3/4 gearset, Quaife front LSD, TRE 4 spider center diff, boostin performance billet bearing housing. Fidanza Stage two (400 hp) front axles, 4-Bolt Rear end.
- Mods-Handling
- 17 inch flat black rims with Achillis ATR Sport tires, Muellerized JIC FLT-A2 Coilovers. ST rear anti sway bar. RRE Rear Strut bar. Ebay front strut tower bar. Energy Suspension bushings. Outlander Brake upgrade and Metal master pads. SS brake lines.
