Haltech Elite 1500 trigger issue
Tom Green
Dec 20, 2021
Orlando, Florida
Hello folks, I’m having an issue with the trigger on my Haltech elite 1500. 1G DSM with stock CAS and ignition. I ran an E6K with no problem. Switched over to Elite with no start. I installed Evo1 maps. Trigger and home set to rising, ignition set to falling. I get 1300 code. Oscilloscope shows good trigger and home signals when cranking. When cranking the TrigSyncLev bounces between Full and None, TrigSynState bounces between Running, Stopped, and Signal found. TrigErr shows Home Pos Err. Wiring has been triple checked. CAS worked fine with E6K. Any thoughts?
I figured it out. The TDC angle is preset with the base map and shouldn’t be changed. Adjustments need to be made to TDC offset, not TDC angle, to bring into correct timing.
Hey Tom! When finding out your issue, were you running into a no-spark situation? Im currently dealing with the same thing on the base tune file and can't get it to run or even kick. Reinstall stock ECU and fires right up.
