Electrical Connector Identification
Tkzdsm
92
4
Sep 22, 2024
Henderson, Nevada
I have one connector that I think that it’s from my aftermarket boost gauge that was installed when I bought it, but it never read boost. It comes through the right side bottom of the firewall. And the other connector that the other mating connector is missing from is what I always thought was something to do with my windshield wipers because they don’t work. If so I have been looking online for the other mating connector, if anyone know what i should look for let me know, thank you, anything is appreciated.
That first connector is a GM Weather Pack connector that would be used with a GM style MAP sensor.
For OE connectors check with Sheridan Engineering: https://connectors.sheridanengineering.com/index.htm
Okay that helps thank you a lot. What would a gm style map sensor connector be doing on that side? I know they are usually used to bypass things like maf and whatnot but i don’t know much more than that.
Electronic boost gauges use a MAP sensor to measure with and send a voltage back to the gauge to display. There would also be a vacuum hose that would have run to the missing MAP sensor for it to get manifold pressure.
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
