electric problem
jony1285
Aug 3, 2010
rochester, New York
have a problem w my wire it keeps draining my battery. i bought two batterys and killed both of them dont know whats cuasing it to do so alternator is new and my fuses are good im not sure if the cables to my battery are right though if you know what might be causing this or had this happen please let me know
i have a drainage in my battery im not sure what is cuasing it. my wire are fine that are to my battery and the alternator is new. my grounds are good but still cant fine whats wrong. i can start my car with a jump but my car wants to die while im driving but first my lights would go down and my gauges start to flicker then after that the car would just turn off and then would start only with a jump
You either have a short, or a bad battery (weak or internal cell is shorted), or a bad alternator. Know that auto stores are notorious for selling bad "new" alternators (which btw are really just remanufactured), especially a certain store which has an abseen return rate. Many people on here have returned bad alts to this store 3-4 times in a month.
After battery is charged (perhaps with a charger while disconnected) what is the measured voltage at the battery with it then connected and car off, off with headlights on, running with headlights off, and running with headlights on? Did you do the battery drain test in my previous link?
Here's a test to tell if bad alt or battery: http://www.dsmtuners.com/forums/new...reeway-electrical-problems.html#post151165661
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
