Artago
- 2,094
- 31
- Nov 30, 2006
North Vancouver,
BC, Canada
Hey all. I've been testing my emissions system because I failed emissions control test twice and I've run into a bit of a curve ball.
So I followed the Haynes repair manual for testing the EGR solenoid which goes as follows:
1. Disconnect the electrical connector from the EGR solenoid.
2. Connect a Vacuum pump to the top port of the EGR solenoid. (This port is normally connected to the "E" port on the throttle body)
3. Attempt to apply 15 HG of vacuum to the EGR solenoid.
4. NO VACUUM SHOULD DEVELOP. If vacuum develops and holds, replace the solenoid.
5. Apply a 12V current to the EGR solenoid.
6. Attempt to apply 15 HG of vacuum to the EGR solenoid.
7. 15 HG OF VACUUM SHOULD DEVELOP AND HOLD. If vacuum doesn't doesn't develop or hold, replace the solenoid.
Ok so I preformed the test and with no voltage applied the EGR solenoid HELD 15 HG of vac, hence failing Step #4. Then I applied 12V and applied 15 HG of vac, and no vacuum developed, hence failing Step #7.
So the EGR solenoid functioned BACKWARDS, hold vac when it shouldn't and NOT holding vacuum when it should.
My questions: Is this normal? If so then the test procedure in the book is wrong. OR is the test procedure correct and if it is, is my EGR solenoid faulty.
Second question: I tested the resistance across the EGR solenoid terminals and measured 67 Ohms. According to a test procedure I found online (not the book), the resistance should read between 36-46 Ohms. So my question is, what should be the resistance across the EGR solenoid terminals?
Sorry about the long post and thanks for any and all help.
Tom.
Tom.
