EGR problems...need help!!!!!
ExtremeEclipse
Jul 9, 2007
St.Louis, Missouri
Ok I've cleared my egr code like 10 times and It keeps coming on. It started way before my exhaust was installed and still keeps coming on. Can anyone tell me where exactly it is so I can change it.
You might want to check your egr solenoid first, or have an electrician do it for you.
If checked and ok then your egr valve might be faulty. They tend to build a lot of
carbon deposits that chock or completely block the egr valve. Your egr valve is located
on the side of the head towards the battery. Under your cam position sensor. The solenoid
should not be very far from there. Can't remember exactly because i blocked off my egr
a while ago. You can check my thread out if you like to get ideas on what these look like.
http://www.dsmtuners.com/forums/420a-bolt-tech/280370-my-egr-blocked-setup-pics.html
