2G EGR block off plug size
This is great reassurance. So it can be done with the head in the car, and doesn't have to be tapped right just threaded in with the plug correct?
Is this really necessary? Bought the stm egr block plate and thought that would be sufficient enough.. now I'm seeing yall are also blocking the port on the head..? does the port on the head have to blocked as well?..im having an issue where I hit 7lbs of boost and thats it! This has been an on going issue for almost a year and NOONE can figure out why 7lbs is all she building. Fully built motor on fp black and can't even hit gate pressure with gate disconnected, local shop thinks the issue lies in the egr head port being open and is acting as an internal boost leak...??
It can be an issue for sure. I had a thermo gasket and the exhaust gasses melted it causing a leak. It was very simple to install a 1/8th block off plug in the port. Just annoying removing the intake manifold
Sweetthanks for the reply..not to bad of a job I guess. I block that off and see what happens! Thanks again! If anyone else has info in this as well...im all ears!!
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
