Effects of timing belt stretch?
sweet97
2,386
18
Mar 6, 2004
auburn, New York
My timing belt is very near a change. With the cam gear cover off there is a bit of flex in the belt. I also notice that when timing my car the CAS is very near the furtest back setting. What effects could a stretched belt have on performance if any? Thanks, Mark
If it stretches beyond the point the auto tensioner can take up the slack, the pulleys can jump timing and then you run the risk of valve damage which can and most likely will reult in having to pull the head.
If you have any doubts, get it out of there
