ecu
hakalasdsm
Nov 17, 2011
clearlake, California
hi guys i was just wondering if anyone can help me i just got my car going and i was driving and the check engine light was on it clicked off and now my car wont start and check engine light dont come on at all just wondering if a need new ecu or if someone new a trick or two please help me
Did you read what i typed. Check for codes. You have to help your self before anyone else can help you. Without you checking the ecu for trouble codes there is no way for someone to just magically know what is wrong with your car.
No fuel pump and no spark i would assume that you have an issue with a cam or crank sensor, or possible the timing belt itself. I would make sure that the timing and balance shaft belts are intact and test the cam and crank sensors with a multimeter.
ive checked all that it was running great then it almost sounded like the ecu clicked and it wont start up since you no how the engine light comes on then turns off it wont even do that is that caused by cam/crank senser since i have the six bolt block with seven bolt head sorry if i sound retarded just dont no just tryn to learn
Pull the ecu and check the caps. If they are good still check for any burn marks or discoloration. If the ecu checks out fine make sure no fuse has blown and if you have a dvom check for power at the ecu in the proper pins and if they are switched that they too work. You can pull up a 2g ecu pinout diagram to find what pins are switched and what are constant
