ecu
1995 brian
233
Dec 16, 2011
Leadville, Colorado
is there any way to check the ecu?
the reason i ask is because i have no spark in cylinder 2 and 3 .
Pull your power transistor connector, and check for corrosion. Then test the transistor itself using the FSM. Common point of failure for our cars.
All you can check for is leaking caps, corrosion, and burns. There is a tell-tale "fish" smell when Electrolytes leak from capacitors. Other than that, check out this link and see if you can find any of the damage shown in the "Corrosion Examples" section.
ecurepairhome [ECMTuning - wiki]
If you have no spark on cylinders 2/3 then I would start looking at the coil pack. The ICM (power Transistor) could be faulty as well, but to correctly check that you will need a Multimeter.
i swapped the transistor from my 97 gsx that is working fine and still no start or spark. checked the coils resistance with the coil disconected and got 12-13 ohms on both coil packs. so whats left other then the ecu that dosent look llike its leaking or any corrosion. cas or ckp?
How would you test the crank sensor?
  • Wanted 6 bolt NT water pipe
    • chrisman287
