ReckReason86
- 53
- 0
- Mar 3, 2012
san jose,
California
Ok so i have looked all over and haven't found an answer to my problem. I have a 96 gs, and i am having problems with a back fire and bucking. I have already swapped out all the sensors and wires and plugs multiple times. The other day i got a hint that it could be my ecu. Now before i go and drop $100+ on a new one i wanna try it out with another. My question is can i use the EDZ ecu from the chrysler 2.4na in my 420na? i can just swap it out but fear hurting something serious. Thanks for your guy's help
), only the one i need. Thanks for all the help
).The wires that run by the egr tube are known to have problems with getting too hot and become fragile, or even burning through. There are wires in there that help the crank sensor communicate with the cam sensor (needed for car to run). If these wires have a problem they can do so randomly and without a cel. These wires are oftentimes jiggled around and not put back in their appropriate wire management. They then get too close to that hot egr tube and it melts or heats them up so they crack.
