Ecu Replacement
Kod
289
Mar 29, 2011
Kingston, Pennsylvania
Well reason I am asking this is because my Anti Lock light has been on for 2 years didn't really think anything of it checked and fuses are good.
Car sometimes sounds like its surging in the head unit area (where the ecu is obviously..) no crank or anything just sounds like a surge and then if I turn the key back and re try to start it usually jumps no problem.
Just had the charging system checked and everything is good.
Lights have been flickering while driving (just started 3 months ago)
Now the horn stopped working and fuses are good.
How do you go about replacing the computer with one that works for your car?
Like do all numbers need to match or only 4 - 5 certain letter / numbers?\
thanks for any information
Pull the ecu and send it to ecmlink guys they can check it over and make any repairs you might need. And while they have it since your 95 if your ecu is EPROM they can socket it and if you ever want a aftermarket chip or ecmlink your set and all you will need is the EPROM chip! :) ecu is super easy to remove, just remove both side panels from center council and look for the silver box behind radio with 4 big wiring harnesses going into it. Only takes like 2-3 10mm bolts and unplugging the harness to remove.
Thanks for the reply will have to check into that :)
Most of your problems have nothing to do with the ecu. It sounds more like a relay grounding problem.
How can I go about that then?
Is their a diagram anyone has of where all grounds should be located?
