1G ECU question swapping ECU ATX to MTX
talondude4
748
14
Mar 9, 2005
Plymouth, Maine
ok i have a 91 talon tsi and i want to change my ecu from a automatic one which came with the car.... to one that came out of a manual fwd talon..... will the ecu swap work... i am swaping injectors and cams so i need the 5spd one to tell it, it has bigger injectors
so is ther any options if i cant use the manual fwd ecu..... other than dsmlink...
sorry to leave this out LOL
my car is awd
the ecu i want to put in is a fwd....
will it work :talon:
AWD vs. FWD won't matter, I had a AWD ECU in my FWD before too, with no problems.
In the auto's I believe the TCU controls all matters of shifting, and it doesn't communicate with the ECU. So M/T and A/T SHOULDN"t Matter .. BUT see below
Only problem you have is the 1G's manual and automatics both have different injector sizes. The auto's came with the 390's, manuals 450's. So you probably will be running rich. Unless you can adjust.
I asked him and he is swapping the 450cc's from the donor car also so he should be fine as far as fueling is concerned.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
