ECMlink ECMlink Connection/cut out
NineThrityONE
75
3
Jan 6, 2005
Denver, Colorado
So apparently to get this thing tuned right....I'm going to need some logs. But at the moment, as soon as the engine starts the program freezes. While I'm researching, I'm also starting this thread so i can make my findings and get some feedback/ideas.
FYI Im running V2 not V3.
One thing i read, is that a voltage drop/spike could interfere with the connection. and right now After the engine starts, I get "Connection in use by unknown user" (or something like that) and the Program freezes.
Now, one thing, that occurred, is that im using a lithium motorcycle battery. Which has no problem starting the engine but doesn't have a lot of cranking time. the battery has 480CCA; So Ill have to test that.
Also One thing I noticed, is that with the Coil pack unplugged. the connection/program WOULD continue recording under extended cranking.
Does it connect and not freeze with key on/engine off? Have you tried connecting after the car is already running?
yes it connects with key on, can see throttle move and other parameters, and change setting. I tried to connect after engine runs, but I get the error as mentioned.
