Ebay 20g 1/8 run
turbojo
164
Oct 10, 2011
hazel green, Alabama
Just wanted to post my Ebay 20g results mod list is 3 inch hood exit exhaust 26psi stock 200k 6bolt 750 injectors maxed out it slipped the clutch in first gear and the tune is rich like 10.5 at wot but it went 1.9 60 foot 5.4954 330 foot and 8.37 in the 1/8 at 86.61 mph
Pretty good times for a cheap turbo :thumb: i had a ebay 20G on my 1g but i did had bad luck, it only lasted like 10 to 15 runs at 19psi, but it kicked hard while it lasted jajajaja a friend on mine has a ebay 16G and its been hitting hard for a long time now, he had better luck than me LOL
Yea mine is doing good I ran it for two Weeks with the waste gate welded shut before I switch to a external wastegate it's made 32 psi with out any problems I thank I need some cams and a intake manifold to wake the setup up
That's really really slow. 2 years ago on new years day my HY35(similar to 20g) went 7.80 @94mph with a 2.10 60'@20psi You got lots of work to do..
Now, you being N/A means higher comp ratio, correct? Not to mention you compared a Holset turbo to an ebay one LOL
I wonder what the difference in you two timing maps were with the 6 psi difference.
I'm currently going back & forth with my tuner about how much boost to run my 20g on pump gas. Debating on how high timing should be.
How are you gonna compare a 20g to a hy 35 your turbo flows way more lbs of air and your in a 9 cm hot side with a better flowing turbine wheel the 20gs choke at about 25 pounds of boost because of the small turbine wheel and 7 cm exhaust housing
a HY35 isn't that much bigger.
It isn't that a hy35 is alot bigger it's just a 20g is a bad turbo to compare to others of similar size because it has the same exhaust wheel as a 14b so it chokes itself very easily so it's very hard to make power on
Ha. Tell that to everybody that went fast back in the day. Tell that to FP with the HTA68.
Yea im not saying it's the fastest thing ever I was just posting the results of my 2500 hundred dollar talon so please stop with all the posts about how fast your car is if you want to post about your car start your own. thread
So this is about 12-13 for 1/4 mile, right? Definitely not the fastest ever, but at only $2500 for everything VS $2500 for just turbo is not bad. Not bad at all.
(At least i hope you meant "25 hundred" and not "250 000")
A true MHI 20g is nowhere near that amount, hell FP sells them brand new for $539.
Yeah I gave a 1k for the car and have 1500 in parts so I dont think it did to bad but the stock 6 bolt is worn out it's got blow bye at idle so im gonna cam it and and try to build a 11to1 motor to try to max out the set up
I'm not encouraging the use of Ebay shit tastic turbos, but I've seen more than one 20G from ebay do fairly well. With the fact that your motor has 200k or whatnot on it, I think you did a good job with what you have. You have room for improvement and if you have the supporting mods behind that chinabay 20G, when you get some better compression in the motor and a genuine turbo it should haul ass. :thumb:
Just remember 11:1 is really quite high for a forced induction motor! I'd aim more for the 9.5:1 area myself.
