ebay 1g flange
sonik619
239
Oct 7, 2008
san diego, California
Ok guys, I have to get a smog done and this is my setup right now.
I have to get my smog done and I bought a 1g bov, So I went to a muffler shop and ask them if they can weld it, they said no because they don't have that kind of flange, so I was wondering if this is a good alternative and if it will just replace it without modification( change stuff around). Thank you guys.
eBay Motors: 1G BOV Pipe Flange DSM Eclipse 90-94 4G63 Turbo Honda (item 380072522216 end time Feb-10-09 09:16:01 PST)
that looks like the actual stock 1g pipe with flange, you will have to make sure the rest of your piping will match up
i advice you just get a weld on flange and weld it on the pipe you have now and do your car a favor and recirculate and not vent from here on out.
I have 1G BOV flanges out the a$$. Pay shipping and you can have one.
Listen to this guy :thumb:
If the pipe jusmx has is similar to the pipe shown on ebay it should work fine as long as the piping diameter is about the same as the hose.
I have pipes and flanges.
I was figuring you'd just need a flange and get it welded (as professionally as possible) to your existing pipe. Using a 1G pipe would be too rough to adapt, and it would create a bottleneck- they're only 1-7/8" O.D.
