1G BOV flange?
mrslow
34
Jul 20, 2013
Crestline, California
I've been having an issue above 4k RPM under boost over 15psi I get a stutter and a lot of misfiring type feeling, trying to figure out what it was and decided to do anti-lag so I could feel the wastegate and BOV to see if they were opening when they were supposed to. Found out the BOV leaks ALOT of air under boost and was wondering what types of BOV will be a direct fit to the 1G flange or will I need to get a new flange welded?
You will need a new flange or adapter. You could mod the 1g to hold more boost.
It's already been crushed, so I figured the BOV itself is just on the way out. I pushed it up to 21PSI and ran it for a day or two before it gave out.
I'm running vented right now. It's already tuned for the difference when venting so that's not an issue, I can run recirc if needed.
