1g bov flange
GSX26
225
Jun 4, 2005
Dousman, Wisconsin
I currently have a crushed 1g bov, I was wondering what other bov's fit this flange (with slight modification, obviously) I have a type-s laying around in the garage that i know can fit, but I hear it's not the best and is a bit leaky. The bov also has to hold a good amount of psi.
Are you about to upgrade and feel that the 1G BOV will not handle it? I use a 1G BOV with a Dejon Tools mod, supposed to hold alot more boost then anything out there, I haven't had a
chance to test it much beyond normal boost levels. But that is a consideration for you. The 1G BOV is pretty good in its own right, although it doesn't have the Bling factor involved. I believe almost any of the Greddy BOV's can work with just alittle modification, although you will have to check with someone who has done it.
you can line up the greddy flange with the stock 1g one. you can drill through the 1g metal flange and fit the greddy one on top of it. its flat on the top and all of the 1g surface covers up the greddy surface. i did it to mine and it works fine. with no leaks. good luck. or...you can go the more expensive way and buy a different flange for different a different bov. its the hard pipe about 6" that replaces your stock flange and piping and is about $30 or ballpark around there off of ebay. type in "greddy type S flange" or whatever bov you want on your car. good luck man. :thumb:
Thanks guys...but i have a type s in my garage. I've read the vfaq or w.e it is and saw how they connect it to the 1g flange, but I was wondering if there was a better bov because I'm going to be stepping up the boost to 24-26. Is the crushed 1g enough, or what's a better one, preferably that can be mounted on a 1g flange with some modification. Thanks :D
o.k. just check out Dejon Tools on the net and then get back to us. Let us know what you've learned. Nuff said!!
