Easy HP?
garrek11
201
Apr 4, 2009
Spokane, Washington
the tech area says that there is a way to hack your MAF by taking off your bottom honeycomb? i can only see one?
Anybody got any good tips on how to get easy HP without having to buy any upgrades?
If your car is bone stock other than the exhaust listed: Cost $0
You can remove the boost controller restrictor (+1psi)
Remove top of aircan or hack it
Modify intercooler splash shield
Make sure your maintenance is good and your car is healthy before any modding
Check out vfaq.com for some how-tos and i'm sure on this site too.
I wouldn't mess with the honeycombs, some do not experience good results. The Gvr4 comes with lower screen removed from factory but uses a slightly different compensation map in the ecu between the two.
You will run lean a little but that can be adjusted. There are actually 4 major pieces to the honeycombe, here's a little paint shop magic for your help. Also you need to remove the bracket on the front, it hill stop you from removing the separate ones. It's held in by 4 screws it should just slip off. It want to use a large pencil eraser to push them out from back to front. Good luck!
He's got a 1g and didn't say anything about adding a 2gMas. They are quite a bit different
Your right :ohdamn: sorry I have a problem paying attention to detail. at least I had a little fun with paint. ROFL
I'm just happy to have it back unscathed. Except for making my boost leak alot bigger it's pretty good. It was easily one the worst days I have ever had sitting a the police station for 4 hours.
MAS. i dont have all 4 of those honeycombs. could that be why im getting absolutly horrible gas milage
oh ok well then ya i can only see one it seems like when i take the filter off at least
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
