Earl's oil coolers
packinkimber45
378
3
May 26, 2006
Boise, Idaho
Hello everyone, I am pulling my motor here in the next couple of weeks. I decided I might change my 91 housing for 90 housing and external cooler while I am at it. I am debating if I should go with used oem cooler or even new vs after market cooler. I have heard of earl's coolers a little bit, tried to search but no luck on info. Any member's running earls coolers, how do you like it. How much did you spend on the cooler? What all do you need besides lines,90 housing,fittings to run this set up on dsms? Which ones do you recommend, size wise? Not really into the track thing, so I dont need a major oil cooler but I would like something that will be decent. I dont have a lot of mods, but the ideal goal is a dd 300-350hp street car. I'll probably get flamed for this but I have no idea so here it goes. Does the lines going to the oil housing have to be certain length? Any info would be great. Thanks.
