Eagle Talon Lights
Jdabishop
136
Nov 9, 2012
mesa, Arizona
So I recently purchased a 95 eagle talon tsi for $1,300 and the previous owner decided to do a shitty eclipse conversion and the rear blinkers dont work but everything else does. I plan on putting the original lights back on and how would I go about rewiring the lights to work like normal.
Tried searching but couldnt find anything.....Thanks in advance
You shouldn't have to do anything I do belive they have the same wiring.
Well the lights for the tail all work but for some reason blinkers aren't working so i don't know if its a fuse issue or what
try looking at the fuse, and the blubs and what does it look like inside the bulb socket.
Hi,
perfect moment to check all of them:D
If there should be one damaged I bet this one is it:cool:
Regards
