E85 with Supra TT pump?
gsxeclipsed
367
Sep 24, 2004
Greenwood, Indiana
I bought a new project and I plan on running the car on E85. I was just wondering if the supra pump would be E85 friendly and more importanly supply enough fuel for my set up. I was going to run pte 1000cc injectors, Aeromotive FPR, anodized fuel rail, all of that good stuff. I will be running a holset hx-35 or hx-40 which ever i can find first. This being my first car with anything more then a small 16g i am not sure of my goals but would like trap in the 120's with awd. enough rambling about all of that is the pump going to supply the fuel and also handle the alcohol content of E85?
I'm not sure what the hx35 or 40 flow in lb/min, but if it's anything over 45lb/min you're going to be pushing the pump to it's limits, and the injectors. 1000cc injectors at 80% IDC will flow just under 45 lb/min, and just about 55 lb/min at 100% IDC, so it's up to you how much you wanna press your luck. That being said you should be able to push your setup a little ways, just watch your afr's and IDC once you get up to that area, and you'll be fine. Good luck!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
