- Thread starter
- #26
TheBoz
- 268
- 3
- Aug 6, 2004
Riverside,
California
0.015"
35psi+
GT35r
Awesome, thanks for the info. I will try to gap down to .018 and see if that cleans up.
0.015"
35psi+
GT35r
I do not get when people say to run a hotter plug on e85..You need a colder plug. I ran 6's like others stated and a ton of knock! Then 7s and still knock. Then 8s and no knock. 8s are perfect on .026 gap.
Because E85 burns so cold and slow you need a hot plug to ignite it.
Well up top the ignition breaks up pretty bad. I am not sure if it is AFR related, spark plug, or timing.
So I have been trying to gap down the plugs and that does not seem to work as well as I would like. So my next step is I am going to run 20* of timing up top and see what happens. When the ignition breaks up it is almost like the car starts to 2step at 8200 rpm. So I am wondering if the car just does not have enough timing up in the top.
I think you are right. It seems like you run a lot less timing then I have observed other people run on E85. Just imagine the amount of power from the additional timing.
Also, the bottom end must be amazingly strong on this engine. Making over 600HP with knock, and still driving away is a testament to the strength and reliability of this engine. Very impressive!
I don't think it's knock. Looks more like a really bad misfire.
Well, it seems like a missfire issue now. But, if you go back to post 17, he speaks of the making 600HP+ with knock taking place.
He cured the knock, and is now plagued with a missfire. This is my understanding of the situation. I might be misunderstanding something, it happens.
That is a new one too me. Typically 14*-16* at peak torque on that big of a turbo is common with advancement from there.
Want to know if you are actually getting knock. Check out this thread. Easy to make tool to listen for it.
www.neons.org • View topic - $29 "det can" how-to
Your sure your not running out of fuel?
Is your wb02 reading right?
Could anything be vibrating?
Yes in pratice that sounds great, however I can show you log file that says otherwise. My car does not like lean AFR's even on 91oct(10.8), Q16(11.8-12.2), and Now E85. I am going to get me a new WB O2 and see if maybe my AEM WB is giving me false readings. On all the fuels, I have tweaked the AFR's lean and rich to see how the logs would react, and I have played with the timing up and down also. Once I get to 30psi, I will really spend a lot of time working on it there.
When I was tuning 30psi on Q16 I did about 28 pulls to dial in the 30psi range. I tested different AFR's, and different timing.
Here is a log from e85 and 12.4 AFR's. I will try to lean it out a little more and see what happens. But I really think that my car like to be a little more rich.
So here are the basics.
2.0 9000rpm rev limit
37r @ 25psi
AEM EMS
Cali E85
So for the last week or so I have been fighting this knock on e85. I have tried everything under the son to get this knock.
I have gone from 12.0 afrs - 13.0afr's
I have gone from BRP7ES @.020 - BR8ES @ .024-.018
I have run lots of timing and very little timing. I am kinda at my witts end here. Any advice will be helpful.
Also if you want the full log file I can email it to you.
As you can see from the log below, the car will start to knock pretty bad at 8200rpm and 12.50 AFR and 14.3* of timing. It starts to missfire and then by about 8500rpm the will buck and just start to loose tons of power.
Current conditions during this run.
BR8ES @ .018
25psi
3* @ peek boost
16* @ peek rpm
