e316g stock fuel pump rewire? and tunning?
boostsickness
33
Mar 15, 2009
mississauga,
Hey guys, so the stock turbo went yesterday. I will be ordering a evo3 16g tomorrow. Right now the car has a full 3" n1 exhaust and a 1g bov, other then that its stock. As for supporting mods for the 16g, can i get away with 550cc injectors with a stock fuel pump rewire? or what do you guys suggest? im trying to keep things simple, and hopefully inexpensive. I have done some searching, but with not alot of luck, also this is my DD
As for tuning goes, im all ears as i have no experience what so ever. I was looking at a stage 3 chip from dsmchips.com, or should i go a different route? I am also ordering gauges and an MBC.
I'm new to the dsm world, and i want to learn as much as possible I hope you guys can help me out. Thanks
First off order an MHI turbo, stay away from knockoffs they often will go like the t-25 except quicker.
At least go with an rewired walbro 190, that way no afpr needed and you wont run into fuel problems along with the 550's.
As for tuning just get an safc, you can tune in 550's easily through some reading on piggyback tuning.
You cant go by other tuners setups because all cars are different. You could always also get a chip that
would tune in your 550's automatically and you could get some other things programmed on the chip. With the chip you would need an eprom ecu, which only came standard on the '95's unless
you have it already.
I am ordering everything from extreme psi, i have heard nothing but good things.
As for the chip this is what i was looking at KEYDIVER Chips - 2G DSM ECU Tuning
and thanks for your input, I'll go with the 550's and a rewired walbro 190
Yeah extremepsi sells good parts. And that 16g will be MHI. I'd also check out
STM - Street Tuned Motorsports.com - Rochester NY
As for the chip, like i said you will need an 2g eprom ecu. They go from $200-250 maybe
cheaper if your lucky check the classifieds. This is unless you have one already, which
they only came standard on the 2g's in 1995.
