E = Empty!!
My gas light doesn't work, but I've gotten 40-50 city miles after the "e" line....i pushed it too far though! I ended up coasting into the gas station driveway, and pushing it [in heels,ugh] up to the pump.
My 2g can get 30ish miles with the light on. I had the light come on late one night and had to get home because nowhere was open, next morning I go to put in gas and get smokes, 11 miles to station, 11 miles home, 11 miles back to the station.... had forgotten my wallet.
Just go its only 20 miles, and you dont have a fuel light on i woulda allready left why are you still posting? Thats how my car looked when i first bought it, and there was like quarter tank. When i took it to the gas station, and filled it up with in 20 mins mt fuel gauge worked again.
i honestly think my gas light doesnt work i drive on e or below e all the time and my gas light has never came on id like to fix but i dont have a clue how to
*sneeze* excuse me. The dust on this two year old thread got to me.
The first step to fixing anything is to figure out what's wrong with it. I think that's standard knowledge that comes with being human, but I stated it just in case.
Here's a few ideas to get you started.....
  • See if the bulb is out.
  • If the gas gauge doesn't work, then the float in the gas tank might be stuck.
  • You might not be even getting the tank low enough for the light to come on.
  • Are you surpassing 400 miles on each tank?
GL :thumb:
Old thread I know.
But I was searching because this is bothering me.
My gas light comes on as soon as I hit the 4th line on the gas gauge, which is just about 250ish miles.
It use to go all the way to the bottom line before the light came on.
What I have done that could have effected it?
1)Installed new fuel pump with rewire (Aeromotive stealth 340lph)
2)Drilled siphon to 1/8"
3) replaced burned out bulbs on back of gauge cluster
When I had the entire fuel assembly out of the tank and wired in I held the assembly as if it was sitting in the fuel tank and turned the key on to see if the needle on the gauge cluster would go to E. With the float all the way down, it did not make the fuel gauge needle go below the 4th line on the gauge cluster.
Bring'en it back from the dead dont want to start a new thread. I have been only able to squeeze a max of 11gal into my 95tsi awd With the E light on. Is there any difference in tank sizes ? Only reason i ask is i have 1/16 tank left light has not come on yet and Ino it works. My towns e85 station is out and they are not sure when they will be getting a shipment in. The nearest station is 25miles from here Im getting roughly 14mpg with E85 LOL So id like to know if 16.5 gal is the capacity of our tanks . If so that would leave me with roughly 6gals left should be more then enough to make it.
