Dyno Sheet & log thoughts
DWR-DSM
903
Jul 5, 2008
Schenectady, New York
Thoughts on the dyno sheet and the log I took yesterday on the street while in 2nd. I made 404awhp and 328TQ with 93 pump. 2.3L 6bolt, PTE 5557 bolt on housing, JMF Swim, Kelfords 272, 1050cc injectors, etc etc
I thought I would see more TQ than 328
I dont see anything crazy going on in the log. The few things i can say are make sure your base timing is set properly. Also Id add a little bit of timing to see if it picks up. Also what was your boost? This log shows boost est at 12-13 psi. Your injector duty was also very low so this setup has a lot of room to grow it seems.
The boost lvl 22.2. I think I should had the tune more aggressive for the start. Think I will retune it on 93 and probably on 110 also.
It doesn't break 300hp til 5300rpm's. Looks pretty normal.
With out being able to read the logs id blame it on the cams and IM. Those both say to me "i dont care about torque" LOL.
People running those cams claim minimal low end loss, but i've seen comparison where they lost 40hp and 60tq in the low end(around 3500ish) to other brands real 272's.
I remember a 16g guy even lost peak power going from bc 272's to k272's and a ton of low end.
I'll see if i can find them, they're floating around here somewhere.
But it could be that your still on low boost? By what rpm are you seeing that 22psi?
I'm seeing 22 by like 5000-5200. It gets up to that rpm in a flash. I was thinking the setup just wants more boost
