95CarbonEclipse
- 1,279
- 5
- Sep 16, 2005
Yakima,
Washington
Okay, so as we speak my old nasty carpet is soaking in a bucket of Oil Eaters degreaser after being pressure washed. While I've got my carpet out, I'm thinking of applying a DIY truck bed liner to the entire floor board area of my car (front and back passenger area along with the spare tire trunk area) for sound deadening/insulating effect. Has anyone on this forum ever done this before? I know that a lot of Jeep guys will go this route for its ruggedness and I've seen it done on MuscleCar (but they had it professionally done). Also, I'd like to hear any tips or advice on what steps I should take when doing this and what would be better, spray on or roll/paint on?
Right now my plans are as follows:
1. Vacuum all loose debris from the floor boards.
2. Lightly sand/scuff the current painted metal as best I can to promote a good adhesion of the liner. I won't be spending a ton of time in this area as the floor boards are corrugated and would take forever to sand every last nook and cranny.
3. Wipe down/Wash the sanded areas to clean up any remaining debris.
4. Tape off fuel pump hatch and any other areas that shouldn't be coated.
5. Apply truck bed liner (either spray or roll on).
I plan on doing just about every section imaginable. Floor boards, inner rear quarter panels, underneath the rear passenger seats, inner roof around the sunroof, along with the entire trunk area (includeing the side panels). I'm also thinking that I'll use some of the spray can stuff to get into those hard to reach area's.
So... I shouldn't have my custom 4" exhaust routed through my backseat?
