Dtc P0120
Lico-solo 99GSX
Dec 13, 2003
Mesquite, Texas
Dtc P0120
My car keeps showing the Malfunction indicator light and when I scan it the DTC is P0120. That is a throtle position engine malfunction. As a fool I went and spend 160 bucks on the Throtle position sensor wich did not fix the problem.
I have set everything according to the service manual but I think I may be missing something because the dam light keeps popping on.
I would like to get my car inspected but it will not pass with the DTC ligh on.
Does anyone have a hint on what to do? Can you direct me to someone that knows?
Lico
:mad:
No SAFC
Man... I had to disconnect the SAFC because I could not get the car to run right.
So I only have the HKS VPC. And.... I can get the car to run strong but the light keeps coming back on after about 3 or 4 stops and starts of the engine.
Thank you, Lico
Big 16g ported clipped 10degrees
Ported O2 sensor housing
Ported exhaust manifold
Lightly ported cylinder head
matched ports
2.5od down pipe
550cc injectors
ACT 2100 clutch
lightened flywheel
High flow cat converter
Walbro 255 in tank high pressure fuel pump
HKS sequential blow off valve
HKS electronic boost controller
Vtech plug wires
HKS high flow intake
K&N air filter
HKS 3" cat back exhaust
Twin Power DLI
HKS VPC
RMR sway bars
Stillen front mounted intercooler
AEM big brakes front
Stainless braided brake lines
2G Bolt on FPR
EGT
Chin spoiler
custom cold air box and duct
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
