blackGSX2g
DSM Wiseman
- 3,334
- 88
- Apr 30, 2004
Kalamazoo,
Michigan
They probably just got cheap with the props and re-used it from the previous one.
The best part of the episode, was the Victorias Secret commercial at the end.
Last season on Ghost Whisperer , there was a 1g that was parked in front the antique shop alot .Dave_Hash said:knowing tv yes. It looks like the show is going to be shit and be F&F like but it has been a while since I have seen a 2g or even a 1g on tv
Um...bubba jet fuel is NOT the same as avgas (100ll and such). First of all avgas is used in piston engines jet fuel isn't. It also has octane rating just like your regular gas and color coded for newbs. It even feels different to the touch if you even touched it. Jet fuel, well as the name implies its for jets. There's Jet A-1, Jet A U.S. only version with higher freeze point, Jet B primarily used in cold climates and has high flammability, JP-4 same as Jet B, JP-5, JP-8 is the same as Jet A-1. um i cant remember anymore. but where in the world did u get that avgas is the same as jet fuel?95blackGsTurbo said:Same as AV gas. I used it all the time in my 4 wheeler. Burns insanely dry though. Just add some Marvel Mystery Oil and you can run it in a carb. vehicle. It might clog injectors.
. Yeah I saw that. and yes "silvawolfe" you must be bored to find those pics.
