DSMLogger Connection Problem
BoostActionBob
40
3
Sep 27, 2005
Minot, North Dakota
i have a logger from dsmloggers.com. i have it all hooked up right and when i plug it into my palm it beeps but i get the little x in the top right hand corner. wondering how to fix this because i cannot log or even view anything for that matter. any help is appreciated. :talon:
I was wondering if you could go into a little more detail?
I had a problem similar to this . If you go into the mmcd program and you pick mmcd on there main page, top left corner. You will get a drop down box that says test or debug. Pick test and run a test on your ecu. If it comes back ecu comm error there is a problem with the logger program, and needs to be deleted and reinstalled on your palm. And try reseting your ecu also, mine wouldn't let me log until I reset. Disconnect your ground cable from the battery for about 30 seconds and that will reset the ecu.
Try this and then let me know if it helped and please reputation points are valued also. :talon:
there is no where i can run a test on my logger. (dsmlogger) i will try to reset my ecu and try again. just did a few things and i need to see my knock count. ahhh! thanks. :talon:
Sorry, I was talking about when you have the logger conected to the ecu. On the screen that lets you start a new log. Tap on the word mmcd in the top left corner and run a test. :talon:
