dsmlink not working
freeman 188
211
Mar 6, 2007
medicine hat, AB, Canada
:mad:just bought eprom ecu and dsmlink but now my car won,t start with it ,even when I put the original chip back in .ecu # md165531 ,this thing had a blown chip in it ic 106 on the board I replaced it but still no go .is it possible the ecu is fried ,and what about dsmlink that was in it when the chip burn,t out .the part # is m5269l ,8 pin ,there is 6 of them in there .
Maybe the chip burned out rechip it check the engine fuses if none of that works then its your ecu
put my factory ecu in and it starts fine
Not sure if it's the same for yours but when I bought link I had the same problem. Didn't realize that the firing order needed to be switched, just switched around the wires and it started just fine.:dsm:
I can't even tell what you are typing. Please use proper puntuation, spelling, and sentance structure.
SmalltownDSMer- The wires don't have to be swapped on a 1G.
shouldn,t this ecu work with the factory eprom chip in it . to clear things up forget about the first post for now . I bought this ecu with the dsmlink already installed in it ,the guy I got it from said it worked fine when he took it out ,even with one of the chips fried in the ecu ,he said it didn,t effect it,s performance at all . now when I tried it in my car it won,t start . what could be the problem:confused:
Are you saying it runs now, but with the fuel solenoid clicking? The fuel solenoid only energizes during cold starts to increase fuel pressure by blocking the engine vaccum from reaching your fuel pressure regulator. You could unplug it. If it runs with your other computer installed, and it won't run with the replacement ECU installed with a stock e-prom OR the DSMlink e-prom, I would suspect the replacement ECU. First off start by telling us what the number on the ECU that works AND the number on the replacement ECU. It starts with MD...
EDIT: Sorry I see the #s now. Hold on Checking.....
I replaced the eprom in the computer ,part number m6111 e827 ,right where the dsmlink plugs into it , it is a square ic about 1" by 1" with 60 pins on it .now the car starts ,but won,t connect with laptop . also all other problems went away that were stated earlier .
I will put some pictures of ecu on later ,so you guys can have a laugh and scratch your heads .LOL
I always put them somewhere else, then copy the link from the address bar and paste it here preceded by this
Like this
