heat not working
Dr DSM
105
Jan 9, 2011
Kettering, Ohio
i was driving my car to work with the heat on full and i hit a huge hole in the road and my heat stopped working. no matter what what setting the air flow knob is on nothing blows out. what caused this and how can i fix it
like its not blowing anything or just not blowing hot? if not anything then i would assume electrical connector or connection. if you lost heat then maybe you dislodged something
Considering you hit a huge hole, you probably jarred something loose. First, I'd check to make sure the connector for the blower fan speed is still seated. Then move on to the relays for the blower motor.
