Dsmlink Injector Qustion
b-morr
190
Jul 24, 2007
Aurora, Florida
I bought a used dsmlink, and the chip is burned for FIC 950's, which is what injectors I will be running. When saying burned that makes me think its permanent. I know you can adjust the Global value for different injectors. But with it burned for 950's is 0% stock and then around 53% the 950's. Or with it burned is it 0% for the 950's?
I think its 0% stock, and then you just adjust the global value for what ever injectors you have no matter what its burned for.
Input?
Correct. 0% is always the settings for the stock injectors. Because your chip is set for 950cc injectors, it will revert back to 53% (or whatever the factory setting is for 950's) global if the battery is disconnected. Did that answer your question?
